Source FlexScript Code
georgia_m2
georgia_m2
new-ideas-cv.fsm
Hey I'm pretty new to FlexSim and I have a question.
How can i make the source create items from an excel file, constantly and randomly?
Thank you,
Georgia
sebastian_hemmannE3JAU
Could you please explain more exactly what you are looking for and why?
mischa_spelt
Have you considered using the Arrival Table or Arrival Sequence options?
mischa_spelt
Also, instead of having 6 "Send to item" actions on each decision point, you can replace them with a single condition of "item.Type <= 6" on the first one, "item.Type <= 12" on the second, etc.
georgia_m2
thank you i will try that !
georgia_m2
worked 🙂 Thank you!!
is it possible to write an expression such as item.type >5 && item.type >2 for example ?
mischa_spelt
Sure @georgia M2, you can use the operators >, >=, < and <= for comparisons, and && and || for and and or. However, in this case that is not necessary because all items with types less then 6 will get sent off by the first decision point, so items arriving at the decision point are guaranteed to have item type at least 7. By the way, note that the the item type label is called item.Type (with a capital)
