sorting to rack cells
georgia_m2
georgia_m2
[ FlexSim 17.2.5 ]
How can i sort flowitems to rack cells according to their label?
the order of the cells doesnt matter as long as the items are sorted according their label.
thank you 🙂
jeff_nordgren
@georgia M2
That's not a lot of information to go on. What exactly is kept in the "label" and on what object is the "label". It would be helpful if you could send your model or if that is not possible for some reason, a sample model showing the area of concern. Sending a model is the the best way for us to help figure out what exactly it is you need. A description, alone, does not help us to know what is happening in the model itself.
Thanks.
georgia_m2
meow.fsm
thats the model ,thank you
JordanLJohnson
You are very close, I think. I looked at each Decision Point, and I saw that a lot of them have two SendItem options used:
This would work fine, except none of the boxes have a Type label. There is a photo eye that is configured to set item type and color. However, because the block time is 2 seconds (and boxes do not block the photo eye for that long), that OnBlock code never fires:
So depending on what you want, you could reduce the Block Time, so that your boxes get a type, or you could just remove the second "Send Item" option, so that the Type is not needed.
Jordan Johnson
Principal Software Engineer
