sorting items (articles) from a conveyor by a joblist
christoph_gruber
christoph_gruber
[ FlexSim 20.1.2 ]
Good day, I have the following problem.
In PF I generate a Joblist (gerneral list) with the different articles (1-5) on an Array. On a conveyor system the articles are circling. I have two DPs on the convevors. On one DP (DP2) I define the Job (at the moment manuel) on a Lable. On another DP (DP1) I will sort the right articles from the job on DP2 to the outgoing conveyor. I have a problem with the "pull from list" on DP1 arrivaltrigger. What´s wrong in my query? Thanks for helping me.
please see the model attached
testmodel.fsm
joerg_vogel_HsH
Query
WHERE value = Puller.Article
value is a reference to the entry of the list. You want to compare item.Article with value of your list. But you can only parse item as a Puller into query clause.
On Pulled
if (numFulfilled == numRequired) {
   treenode newDest =current.outObjects[1];
   Conveyor.sendItem(item, newDest);
You need a senditem action, too.
christoph_gruber
thanks a lot Jörg!
