Skip First Delay Time
doris_c
doris_c
[ FlexSim 19.0.0 ]
Delay time is applied to AGV Elevator in current modeling. The motion I want is that the first AGV goes through without delay. Delay time shall be applied to all subsequent agv.
It's a control I've always wanted to try, but I still don't know how to do
delay-time-test.fsm
moehlmann_fe
You can use the "Time by Case" optoin in the delay activity and use the input statistic to determine if the token is the first to enter or not.
To get the "getstat()" command you can use the sampling tool and click on the activity. By default it will contain "Output", which you can change to "Input" (or you use a delay of 0s if the output is 0 and 10s otherwise)
