single processor with different processing times with quantity limits
OllyR
OllyR
[ FlexSim 24.0.0 ]
I'm currently doing a project that requires me to make an assembly line with different palatized parts going through it. So far I've managed to get 2 different item types through the processor with different operation times however I'm struggling to set a limit of 1 of each item on the processor at once. Currently the processor will take 1 of each item at the start, then it will take one part at random meaning I've now got 2 of the same item type on the processor which isn't what I'm looking to achieve. Part 'x' takes 16800 seconds to complete and part 'y' takes 3200. I've tried using zones in the process flow with subset constraints but i cant seem to get it working correctly. Any help would be appreciated. i want to make sure the processor doesn't pull a new item from the queue unless its finished with that set item type already.
For added context here is my attempt at this so far.
https://drive.google.com/file/d/1aQcX3nRDq2E1g0ixVnuwea9QDyeWj1w9/view?usp=sharing
jason_lightfootVL7B4
When posting models to the forum try to clean all the exceptions in the SystemConsole first - they are telling you useful points about problems with your model. Post it again when you've cleared those. Let us know if you're having trouble identifying the cause of the messages.
Hi @OllyR,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
