Single Icon Display In User Library For Objects With PF - Droppath
arunTTT2P
arunTTT2P
[ FlexSim 23.1.3 ]
If the user library has an object PF, while saving it in the user library they are displayed as individual objects in the user library. Ideally, it should be displayed as a single icon in the user library.
So to include the objects in a single icon. I have created a drop path attribute and added them to the user library. Even after adding the drop path the object pf is not getting added to the object which is drag-dropped into the FlexSim model. How to fix this?
Attaching the userlibrary for reference.
Arun KRCustomLib.fsl
jason_lightfootVL7B4
Just put the process flow in an attribute of the library as a folder so it's hidden. No need for custom drop scripts etc.
arunTTT2P
Thanks process flow works fine but while adding the conveyor visuals an exception is thrown. How to fix this?
exception: Exception Caught in ObjectFunction253__project_library_FlexSimObject_behaviour_eventfunctions_OnPreDraw object: /Plane4/StraightConveyor1 class: /Plane4/StraightConveyor1
exception: Exception caught in TreeNode::receivemessage()
exception: EditorSpatial::prepareDraw()
exception: Exception Caught in ObjectFunction232__project_library_FlexSimEventHandler_behaviour_eventfunctions_OnDraw object: /ConveyorSystem i: /ConveyorSystem class: /ConveyorSystem
exception: EditorSpatial::drawContent()
exception: treewin__CallUserCallback
ex: CallUserCallback
Lib.fsl
I would place the hide folder in the attribute part of the library object - not in the part that gets displayed in the grid.
In this case I think the conveyor in the plane was not pointing to the visualization type.
Fix attached.
lib_hiddenConvVisualization.fsl
