Message 1 of 9
[ FlexSim 21.2.1 ]
Use the attached model. Let's assume I have more objects 3 and 4. The model has a task sequence or built-in dispatcher (built-in, assume it was a default setup from a special library, let's say I have inherited from a former programmer). Can I incorporate the current task sequence (or the dispatcher) with the process flow to make the following route (I don't want to change the reset code, more user-friendly simulation)? TaskExecuter1 go to object1,2,3,4. 1,2 task sequence, 3,4 process flow.
