Simulating Different Order Picking Routing Strategies
Hi everyone,
I’m simulating different order picking routing strategies in FlexSim, currently using the Return strategy as the baseline.
To make sure my results are realistic and statistically reliable, I have a few questions and issues I’d really appreciate help with:
How many orders and replications should I simulate to ensure statistically valid and real-world-representative results?
Are there general FlexSim best practices for determining these values?
I want to define a warmup period to avoid skewed metrics caused by an initially empty system.
How can I implement this so that FlexSim starts collecting statistics only after the system stabilizes.
In other simulation softwares, I used a cycle time graph to visually identify when the system stabilizes.
How can I create a similar graph in FlexSim?
I want to visualize cycle time/order time per order and see where the values stabilize so I can identify the proper warmup cutoff.
Is there any way to automatically detect the stabilization point using moving averages, variance thresholds, or built-in FlexSim tools?
Labeling Logic and Assignment Issue
I used labels as follows:
Pallets were labeled with Type
Boxes were labeled with SKU (e.g., 101, 102)
Initially, I painted rack slots based on Pallet Type but this resulted in SKUs being placed in slots with mismatched painted numbers.
So I changed the slot painting to only reflect the SKU
This fixed the slot-SKU mismatch, but now I must enter box quantities, not pallet quantities so I enter 1000 in quantity and not all slots are assigned.
When I scale the simulation to 200+ orders, the model pauses or freezes several times during the run.
Is this expected behavior, or is there something wrong in my labeling or assignment logic?
I also want to track the time taken and distance traveled to pick each individual order.
How can I record this per order and store it in a global table or log it in FlexSim?
I’d like to export it or plot it later (e.g., total time and distance per order on a chart).
Thanks so much in advance for any guidance! I’d be grateful for help on any of these points, especially if anyone has tackled similar order picking scenarios.
