[ FlexSim 16.2.1 ]
Hello.
In my model, I have a scheduled source with items arriving at time 0 that have 4 different dimensions. The dimensions are assigned a label that represents if a dimension change is necessary before that dimension is processed. There are two types of changes (long and short) and if that dimension requires the change, the label is 1. If it doesn't require the change, the dimension is 0.
I can get the processor to shut down based on those labels, but it shuts down after every item because they are all assigned the label, which is not what I want. Is it possible to have the processor only shut down one time before the next dimension is loaded?
For example, if the last item of dimension 1 is on the processor, the processor will finish that item and then shut down for X time because the next item is a different dimension. Then after the shutdown, the item from dimension 2 is loaded. And so on for all the dimensions.
Thanks for the help.
