Simulate Changeover
Simulate Changeover
sandy_huang
Simulate Changeover
sandy_huang
Hi, I'm new to FlexSim. What is the best way to simulate changeover for the attached test model? Changeover is triggered when a different product type enters the line. All processors stop when changeover is triggered.
test-model-20170228.fsm
Thank you!
Sandy Huang
jing_chen
Hi, Sandy.
I add a label "type" to record the itemtype in M1, and another label "change_time" is the time use for Changeover.
I try to determine whether item is different one in the OnEntry Trigger of M1, if so I will close input, change the color of M1 to red and send a delay message for resume.
You sure of "All processors stop when changeover is triggered"? Because some items maybe still in other machine. My approach is only close input of M1
Is that what you want? May it helps~
changeovertimev17chj.fsm
sandy_huang
Thank you @jing.chen
This should work if the "delay" can be set to start after all items in the system are processed (reach the "Sink"). Can such logic be added? Also I couldn't find where to get the "Delayed time" statistics.
jing_chen
Sandy, I modified my model and add a ControlCenter to control the changeover with some labels and code.
When item come into Queue1, OnEnrty trigger will evaluate the item whether a new "product type". If so, the label "batch" will change to input number of Q1 which it determine the start time of changeover(a delay message will be sent from sink to ControlCenter)
On the message trigger of ControlCenter, it will stop the machine with STATE_CHANGE_OVER and back to normal after "changeover" time.
Changeover time now is an fixed value you can find it in label"change_time" of ControlCenter, you can change based on different product types.
By the way, I'm not sure about judging "product type" is based on itemtype or Product ID. This time I choose to use label "Product ID"
changeovertime2v17chj.fsm
May it will help you~
sandy_huang
Thanks Jing. Your reply is very helpful!
jing_chen
Hi Sandy~ You can accept my answer, if it help you solve your problem.
