Simulate a temporary setup area.
thomas890524
thomas890524
As title, I want to simulate an area (for example : office area) which acts the place that operator do setup work.
How can I simulate this place which is away from processors?
Thanks~
moehlmann_fe
You mean the operator should not travel to the processor as part of fixing the "breakdown"?
Just send them to a different object in the downfunction. Or even remove the travel task alltogether.
renau_lecomte
 This technique is not the best but works anyway with ProcessFlow
1- As trigger : when your item enters the processor (it means it starts with the settup)
2-Create a Task Sequence, with the operator you want to use.
3- Make the operator wait with the delay activity in the TS options. With the delay, you can by using the good statistic state
For this you need to untick the use operator for the settup in the processor.
Let me know if it works,
Sincerly,
Renaud
