shape frames
shape frames
amy_milesB7Q7X
Message 1 of 8
shape frames
amy_milesB7Q7X
[ FlexSim 21.2.3 ]
Is there a way to get a flow item as a shape frame in anther flow item? I am using the box as the base. Then after a process I want it to look like it has a top cap. I duplicated the box and added a top to it in animations so it shows up as another flow item. I can't figure out how to get this new one added as frame 2 to the original box flow item. I can't find where it's saved. I tried adding to a user library but don't see it anywhere. Is this even possible?
Replies (7)
Message 2 of 8
ryan_c10
Hi @Amy M3, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
Message 3 of 8
amy_milesB7Q7X
Are there any other options? I guess it's helpful to know if it's not possible...would be nice to be able to do simple shapes in flexsim though, I haven't ever used 3d editors.
Message 4 of 8
Jeanette_Fullmer
Hello @Amy M3 ,
You can read about creating and importing 3D object in our manual. There are two other resources referenced for creating or finding 3D objects that can be used in FlexSim.
Message 5 of 8
amy_milesB7Q7X
I did look at that part in the manual but didn't find an answer to how to make one of my modified flow items a frame. Sounds like only option is to use external editors?
Message 6 of 8
joerg_vogel_HsH
Yes. There does not exist an design editor for frames. You can add mesh vertexes by code, you can add drawsurrogate objects in animation creator. You can draw a box by code. You find here at answers suggestions for external shape editors.
Message 7 of 8
amy_milesB7Q7X
Ok thanks, I did figure out how to make it in animations, just not how to use it. I'll have to dig into how to use external editors.
Message 8 of 8
ryan_c10
Hi @Amy M3, was one of Joerg Vogel's or Jeanette F's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
