Setting priority on conveyors
joshua_fischer
joshua_fischer
[ FlexSim 16.1.1 ]
I was wondering if you could help me out here I’m looking at these scope of operation.
SEQUENCE OF OPERATIONS
The system consists in two conveyor lanes that merge into one. The conveyor lane A2001 will have a higher rate, so that it will have priority at the merge. In normal conditions the boxes on conveyor A2001 will be passing through the merge conveyor A2003 and the boxes on conveyor 01 will be stopped right before the merge. When a pre-determined number of boxes are accumulated on conveyor 01 (defined by the location of photo-eye PE01-FL), the boxes on conveyor A2001 will be stopped before the merge and the boxes on conveyor 01 will be released. When all the boxes that were accumulated on conveyor 01 have passed, the new incoming boxes will be stopped and the boxes on conveyor A2001 will be released, resuming the normal conditions.
When the boxes on conveyor 01 are being released, if there is a number of boxes traveling back-to-back (no gap between them) enough to cause to accumulate boxes on conveyor A2001 up to the photo-eye PE2001-FL, when that photo-eye detects the accumulation, the motor of conveyor 01 will be stopped and –after a delay- the boxes on conveyor A2001 will be released. When all the boxes that were accumulated on conveyor A2001 have passed, the new incoming boxes will be stopped and the motor of conveyor 01 will be started again, returning to the previous condition.
When the photo-eye PE02-FL detects accumulation or a “jam”, the motors on conveyors 01, 02 and A2001 will be stopped and a Beacon Light will be turned ON, indicating that a jam has occurred. An operator will then need to clear the jam and press a “Reset” pushbutton, which will turn OFF the Beacon Light and will also turn ON the motors that were stopped, returning to the previous conditions.
conveyor.jpg......................................................................................................................................................
I’m have trouble with making one of the conveyors have priority over the other. And I want it to release priority if a condition is met and take it back if another condition is met. Using just decision points and Photoeye at the moment but no luck.
If you would like to see more of the scope of operation let me know.
sam_stubbsYXX86
@joshua fischer If I'm understanding what you're describing, I think this section of the manual can help you set up the merging system you are trying to build.
Merging and Slug Building
Have you already gone through this section of the manual and each of the steps for setting it up?
joshua_fischer
These helped greatly, the last thing i have is i can't make conveyor 1's motor stop with a photoeye on a different conveyor (conveyor A2002). after that i would need to know how to restart the conveyors motor when that photoeye becomes clear and provide me with an adjustable delay.
also as you can see in the picture that i provided, the boxes that are coming in are going in a straight line so the boxes coming off of A2002 are then moving on an invisible conveyor after moving off of A2003 how would i fix these?
adrian_haws
@joshua fischer See this link for instructions on using a conveyor motor. I've attached an example model of how you might stop and resume a motor from a photoeye.
I'm not sure what you mean in your second question. It would help if we could see an example model.
joshua_fischer
conveyorsystem-autosave.fsm
here is the model so that you can see what i'm talking about in my 2nd question.
sam_stubbsYXX86
@joshua fischer I answered your other question, I believe in this situation the Merge Controller will handle which boxes can go through, if you're using slugs. The photoeye in this case would be redundant.
As for the offsetting of the boxes. I simply added a decision point where the first conveyor meets the main one, and in the OnArrival trigger I added a "Translate Item" function. You can play with the numbers to set the location and distance it takes. (The below example used 2.5 for the Conveyor Left, and 10 for the distance, everything else was 0 or blank.)
