Settablenum function can't work in Pull Requirement trigger
johnson23905
johnson23905
[ FlexSim 18.0.10 ]
Hello everyone,
I want to realize a material flow when queue pull item from source,the number of global table "demand" first row first col will reduce 1.
Although it will pull items according to number of "demand",the number of demand won't reduce.I don't know where the problem is, please help to solve it.
Thank you very much! Best regards.
joerg_vogel_HsH
Please swap the source code lines. No code lines are executed AFTER an executed return statement. It is totally independent on the block curled braces.
johnson23905
Thanks!It really helps a lot!
