- Mute
- Permalink
- Report
[ FlexSim 21.0.0 ]
I'm trying to resize a robot in my model using a script. I've tried to use the method that i generally use for all the objects:
Object obj = Model.find("Robot1");
double x = 0.5;
double y = 0.5;
double z = 0.5;
obj.setSize(x, y, z);
This operation doesn't work for the robot (the values in the properties are changed but the real robot dimensions in the model aren't).There is a solution for this problem?
