Set Rotation and location on Transporter
john_an
john_an
[ FlexSim 18.2.3 ]
- Transporter to change set location (on forks) of just flow item types 1 and 2 onLoad (any position is fine, just trying to figure out the work method.
- Transporter to rotate just flow item 3 (cylinder) to lay on it's side onload (just want to figure out the work method also.
All other conditions in the attached file remains the same. (One item is transported at a time.)
22984-transporter-item-location-by-type.fsm
joerg_vogel_HsH
If you transport only one item, then you need only to put around the set rotation picklist option template source code a condition statement.
if(item.Type == 3){  /* picklist template for rotating an item */}
rotate-one-item-by-type-on-transporter.fsm
john_an
Jorg,
Thank you very much. Makes sense. I appreciate.
