set process time using parameter table
supportPHJ4A
supportPHJ4A
[ FlexSim 22.0.0 ]
When I use parameter table to set process time,if the default time unit is hours(Or other non-seconds unit), time unit will automatically switches back to seconds.
Matthew_Gillespie
Setting the property through code overwrites the units of that property. However, you can also set the units of the property through code. Open the code of the On Set trigger and change
setProperty(propertyName, newValue)
to
setProperty(propertyName, [newValue, "hr"])
to set the units to hours.
Matthew Gillespie
FlexSim Software Developer
