Set percentage of patients in function of label
Ayman02
Ayman02
I have a "Decide" box that is connected to two boxes. If there are 5 different types of patients (label), how can I set a different percentage of patients that goes to each box in function of the label?
sebastian_canas9DYX7
@Ayman ,
It depends if you're setting a label from the beginning or you just want to set the percentage directly in the Decide activity. However, this is easily done using the picklist options of that activity.
I would suggest you to walk throught the FlexSim HC tutorial, focusing on this task, where you could learn how to create a conditional flow.
Ayman02
I think I have not explained myself correctly. I have created 5 type of patients according to their severity, each one with its label set.
For each of these patients, I want to set a percentage that goes to activity 1 and another percentage to activity 2.
For example: Patient_type1: (70% go to activity 1 and 30% to activity 2)
Patient_type2: (60% go to activity 1 and 40% to activity 2)
@Ayman ,
If you have two possible destinations for each type of patient, you could use a bernoulli distribution within the Connector by case option of the Decide Activity.
You set something like this:
Change the Case Function and the values according to your model
Is that a more accurate answer?
Jeanette_Fullmer
Hi @Ayman, was one of Ayman's or Sebastián Cañas's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
