Sequence of events for Astar navigation
rhramac
rhramac
[ FlexSim 21.2.4 ]
What are the sequence of events such as calculate path, navigate Path. What is Astarblock, Astar continue etc.? I was not able to find it in the documentation.
jason_lightfootVL7B4
At the start of travel:
  1. OnCalculatePath
  2. OnNavigatePath
Then when there's a conflict:
  1. OnBlock
  2. OnContinue
  3. OnNavigatePath
rhramac
Are there any other events like as a task executer moves from one cell to another? I am trying to add dynamic barrier to account for bot that extend into other cells. So mostly like a dynamic barrier that moves with the task executer.
None that would help with that as far as I can tell. You could consider if adding an Agent System would give you some more events through which you could modify behaviour.
I believe there is already a request to better support task executers that occupy more than one grid position.
rhramac
Yes I see that few folks have requested for it before. Waiting to see if that would be part of future releases.
