Separator - Split 1 item into 2 & Route them based on label
ana_pc2
ana_pc2
[ FlexSim 20.2.3 ]
Hello everybody,
I have a small question about how to split an item into 2, and route them based on a label. Please find attached a basic example model where the Separator - Send To Port Custom Code is still unfinished:
Object item = param(1);
Object current = ownerobject(c);
/**Custom Code*/
if (item.Type == 1)
    return 1;  // return both splits to port 1;
else
// send 1 split to port 2;
// & send the other split to port 3;
I hope it makes sense what I am trying to do 🙂
Thanks for your help!
Ana.
ana_pc2
joerg_vogel_HsH
@ana.pc2, let a queue do the round robin send action.
The separator sends items by “Port by case“ or “by expression”. A queue at exit port 2 or port 2 and 3 sends items in round robin property.
joerg_vogel_HsH
This answer uses an object as a replacement for a source code. A model is still an imitation of reality. If you don’t want to show objects, which are present just for a logic purpose, then you can still hide them.
ana_pc2
Yes, it could be an option. I was just wondering if it could be done on the same separator, but thanks for the reply! I will do that 🙂
