Separator - How do I split a work item and send to different output ports?
cam_seams
cam_seams
I have 2 work item types in my model: ItemType1 and ItemType2.
Both ItemType1 and ItemType2 enter the separator.
ItemType 1 does not need to be split, only processed and then sent to a specific output port.
ItemType2 needs to be split into 2 work items, then 1 of each of the split work items needs to be routed to different ports. If one of the output ports is blocked, then neither of the newly split work items can exit the separator.
I do not have the option to send ItemType2 to 2 different output ports, while also holding block restrictions on it within the flow tab. Looking for some help on this one, thanks.
-Cam
sam_stubbs
I think I may have spoken to you over the phone. Like I said, you'll probably find the easiest way to control your logic is with a Process Flow.. I've created a simple example that does roughly as you described, that turns a processor into a separator. (The last requirement of having the items stay in the processor could be achieved using Resource acquisition or Lists)
Here is my sample model for you to look at.
simpletest.fsm
jeff_nordgren
@Cam Seams,
Here is an example of using Resource acquisition as mentioned by Sam to make sure that both output destinations of Processor1 are free before releasing either item.
simpletest-jn1.fsm
cam_seams
@Sam Stubbs
Yes this is is exactly what I was looking for. I am still on version 2016 however, and it looks like the 'token.processor' type of object is not available. Are there major differences in the process flow tool between 2016 and 2017? Having a difficult time trying to replicate this in 2016.
sam_stubbs
Process Flow should be the same, the only differences are in the new dot syntax of the Flexscript and new variable types. But the logic should work the same.
