Separate sub-packed items
heitor_andrade_porto
Hello, im trying to separate a wing that i combined with a support that i created. On the wing i also combined the flaps and ailerons. So i want to separate the mounted wing from the support.
joerg_vogel_HsH
In fact you want to demount a part of a assembled structure. That is not unpacking. You can use instead the command moveobject. If the part can be demounted in realty without other sub-parts then you should think about a different structure and insert another level in your assembly or move the part to another root point
Thanks! And what do you mean by "insert another level"?. And can u indicate me something that shows me how to add another root point.
