separate 3D objects dependent on planes from low dependent connections
kimsh
kimsh
[ FlexSim 24.2.1 ]
Hi.
Like the picture below
Is there a way to simply separate 3D objects dependent on planes from low dependent connections? Instead of copying and pasting, I want to keep the 3D object and PLANE position by simply separating the 3D object and PLANE.
Paula_LG
If you open the Edit Selected Objects tab (View → Edit Selected Objects), you can do that by selecting the 3D object (or objects) so that they're marked in red (Ctrl/Shift + click over the object/objects) and then clicking on the "Move into model" button on that tab.
To be able to select the "Move into model" option there can't be any 3D object highlighted (marked in yellow) on the model. You can click at any empty space on the model floor to ensure that's the case.
I hope it helps!
kimsh
great!
