Sending operators to a home location when shift is over?
aidan_w1
aidan_w1
[ FlexSim 20.2.0 ]
I'm trying to make it so the operators in my model go to a home location when they are off shift to help keep clutter off of the screen due to the volume of operators I am working with. As it stands currently, when the shift ends, the operators stay in place but no longer operate. I would like them to go to a designated location so it is easier to see how many workers are actually on shift and where everything is while the model runs instead of having a ton of operators scattered around while off shift. How can I go about doing this?
joerg_vogel_HsH
The Brute Force method would be to set a new location in the trigger of your time table for the involved members. If you want them to walk, you create for each involved member of your time table a tasksequence to travel to a location.
Time Tables > Functions > On Down Function
jason_lightfootVL7B4
And you can also add a delay function for the off-shift duration.
aidan_w1
If the shift is covering 20+ operators what should be in place of the Object value in the Set Center Location to avoid this error?
Flexscript Error MODEL:/Tools/TimeTables/Shift1>variables/downtrigger Line 18 Undefined variable involved being used.
Flexscript Error MODEL:/Tools/TimeTables/Shift1>variables/downtrigger Line 18 Could not resolve setloc overload based on passed parameters
Could not finish parsing because of previous errors.
Or show us with a screenshot. We were suggesting you use this:
aidan_w1
That does the trick, thank you
