Send to port by itemtype
edward_ellis
edward_ellis
Hi I have a quick question. I want to validate the itemtype and in the case that it has getitemtype(item) == 1 or 2 I want it to go to certain ports. It is working when I state getitemtype(item) == 1 but how do I add to validate for 2 as well?
Do I use commas, or, what do I do to validate the itemtype for both 1 or 2?
Thank you for your help!
Edward Ellis
adrian_haws
Edward,
If you want to send itemtype 1 for port 1 and itemtype 2 to port 2 you can use the "Port by Case" picklist option in a fixed resource's "Send to Port" field. This is what that might look like:
If you want to send an item to port 1 if itemtype is 1 or 2 you would choose "Conditional Port" with syntax like this:
joerg_vogel_HsH
switch(getitemtype(item))
	case 1:
	case 2:
		return 1;
	default:
		return 0;
As long as there isn't a break or return-command the structure is computing from above to bottom. If case 1 becomes true the code executes in the case 2 the return value. Otherwise default:
