Select Merge Controller connections
clair_augsburgerZGWRZ
[ FlexSim 23.1.1 ]
To delete a connexion, it's very easy: you click on the connection and press the Delete key.
However, this does not work with Merge Controller connections because you can't click on it.
Is it on purpose that Merge Controller connections cannot be selected with a simple click like all other connection types ?
Hi @Jordan Johnson , do you have any feedback on this topic ?
JordanLJohnson
Thank you for brining this to our attention. There are many objects with custom connections (AGV Control Points, Merge Controller, etc.). I will add it to the dev list to see if we can implement this for each of those.
Jordan Johnson
Principal Software Engineer
Matthew_Gillespie
@Clair A This issue has been fixed in 23.0.11 and 23.2.1 released today.
Matthew Gillespie
FlexSim Software Developer
