Scroll Group List
Scroll Group List
maryamh13
Scroll Group List
maryamh13
Hi, when I try to check if an object belongs to a group, I can’t scroll down to see the full list. Is it a mouse focus issue or does the list have a fixed size? there another quick way to check this?
SebastianCanasV
@maryamh13 , I've also had this problem and I guess it's some issue with the UI. Try using the isMember method.
joerg_vogel_HsH
Maybe you use a scaled resolution of your display settings. Some user interfaces don’t take into account that a scaled display resolution reaches visible boundaries of your display. A response should activate a slider.
maryamh13
@SebastianCanasV Okay, thanks!
maryamh13
@joerg_vogel_HsH Thanks for the suggestion. But changing my display scaling or resolution every time I use the app isn't practical. If that fixes the issue, it seems the UI isn't handling scaled displays correctly.
