- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 18.2.2 ]
Hi all.
I have a question for you, is there any default option in FlexSim, when using the "Release Token" that extracts the "token" that are inside the "Delay", is saved the time that elapsed?
For example, I have a "Delay" with time of 20 seconds, some activity triggers the "Release Token", but the "token" that was in the "Delay", only 12 seconds passed. My question is to know if there is any way to save the time that elapsed within the "token" or the time it took inside the "token" to complete the 20 seconds, is this possible?
I thought about doing the following example model but using a "User Event", for when the "Release Token" extracts the token from the "Delay" by means of an "Assign Labels", assign the time that was needed.
Is there any other way to represent this?
