[ FlexSim 18.0.5 ]
after updating my library from FlexSim 17.0.13 to 18.0.5, I noted that FlexSim asks me every times that I create a new model to save the previous one even if I just start the software.
I believe that the issue due to the code "MAIN:/project/exec/globals/nodefunctions/shouldpromptforsavescripts/processFlow" which recognizes the process inside my library like a model process, then FlexSim asks me to save it.
Does someone experiment my same case?
To reproduce the issue, I tested this sequence:
- install testLib.fsl inside standard FlexSim folder (I attached the file testlib.fsl);
- start FlexSim 18.0.5;
- click on "New Model" option of the start page;
At this point message "Do you want to save the model?" appears.
Have you any solution for this problem?
I don't test, but I believe that the issue persists also in FlexSim 18.1.1.
