Save bug - Rack size reverts back to "old" size after load
guldbergdk
guldbergdk
[ FlexSim 24.0.0 ]
I got these racks that I need to scale down. I select them all and enter a new X scale.
But when I save and load the model, its right back to the original size.
This must be a bug, but is there a know way to get it to accept the size?
lars_jacobsen_ScandiSim
Rack size is defined a bit different from most other FR object. The rack size is based on the slot dimensions and the number of bays and levels. See "Edit Dimensions" in panel "Storage Object" in properties for a specific Rack.
User Manual Storage Object - Go to bottom of page
The dimensions are available as MAP.
jason_lightfoot_adsk
Can you try using the size handles on the orb rather than the field in quick properties? If not, why do you want the bounding box to not reflect the size of the rack bays and levels?
Hi @Guldberg, was Lars Christian J2's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
