Salidas del Processor
marylin_p
marylin_p
[ FlexSim 21.1.4 ]
Hola. Por favor, necesito ayuda en el siguiente enunciado:
El processor recibe 3 tipos de productos con llegada exponencial (0,5,0) y puede generar 2 tipos de productos en tamaños diferentes, pero los más grandes se producen cada 10 productos del mismo tipo.
Gracias!!!
Jeanette_Fullmer
Hello @Marylin P ,
Can you try re-explaining your scenario? It sounds like a processor receives 3 types of items at a certain rate and then outputs 2 items at a certain ratio. What is the cause for the items to change type?
marylin_p
Hola. Gracias por responder.
Me explico, entran 3 productos (tipo 1, 2, 3) al procesador y de este salen en 2 tamaños. Pero, un producto grande se crea cada 10 productos del mismo tipo (1, 2, 3). Entonces, no sé como hacer, para que después de pasar 10 productos del queue 1, 2, ó 3 se cree un grande.
Este es el modelo:
Jeanette_Fullmer
Hello @Marylin P,
It might be better to have process flow control the logic to decide when an item needs it's visual changed to look large.
MarylinP_JF.fsm
Also, one last thing for your information when using the forum. It makes things a lot easier when you attach a model with your question. Please consider doing this in the future.
Ben_WilsonADSK
Hi @Marylin P, was Jeanette F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
