Runtime termination of user Event
aaditya_j
aaditya_j
Can we disable user event in run time? after some iterations or model time?
joerg_vogel_HsH
have you tried to wite the condition directly in the user event code like
if(time() < 1000)
   // execute your previous FlexScript source code
aaditya_j
but the event will always be fired right?
joerg_vogel_HsH
yes. You have an option to repeat in the user event? Perhaps you can change the flag or value in an attribute node dynamically. But I am not sure that you can manipulate this after hitting run.
aaditya_j
Anyways the model is speed up with using time()<XXX thanks for the support
joerg_vogel_HsH
The Repeat event option is a variable. You can activate and deactivate the value by FlexScript source code. You need the reference to the Event Object in the model tree in the subtree Tools.
setvarnum(userEvent,"repeat",0);
This deactivates the repeat option. If you need the ability to repeat the event after reset you have to activate it manualy in the user event properties, or by an OnReset trigger and source code.
aaditya_j
Thanks this seems to be better option for me.
