Running simulation multiple times without changing experiment variables?
katherine_lourie
katherine_lourie
[ FlexSim 16.0.1 ]
Is there a way to run a simulation multiple times without actually changing any variables? I need to show average data on the dashboard from multiple runs. Thanks!
Matthew_Gillespie
You just need to change the number of Replications per Scenario on the Experimenter.
Changing the number of replications will change the number of columns on the Status window. As you can see it's doing 5 Replications per Scenario.
Scenarios represent a version of your model with a certain set of variables.
There are two scenarios which show up as the rows in the Status window.
Matthew Gillespie
FlexSim Software Developer
katherine_lourie
So even if I don't have any variables at all (just want to run my exact model multiple times), it should work this way?
Matthew_Gillespie
Yes, for example I made a simple model where patients walk in and then immediately walk out.
I ran 5 replications with only 1 scenario and no variables and got the following throughput graph (number of arrivals):
Matthew Gillespie
katherine_lourie
Thanks!
marcos_mna
Hi @Matthew Gillespie, I am trying to run multiple times a model without changing any variable, I add a percentage in order to separate items with a probability function and I want to collect the data of the states of the processors in multiple times. I do not know if it is because I am using a trial version of the software but I can not access to the Experimenter part. I attach you a photo of how it is seemed. Thank you!
Matthew_Gillespie
Matthew Gillespie
