Run multiple replications and collect data
bryan_suharik
bryan_suharik
[ FlexSim 16.2.2 ]
How can i go about running multiple replications and having the global table update for the values of each new run. In the image, the mean, min, max, and count of units needs to re-average for the amount of run times a user defines.
Thanks!
Bryan
kari_payton
@Bryan Suharik you can use the experimenter to run multiple replications. There is a post here about updating a global table using experimenter, but it is using FlexSim Healthcare.
Second thing you may try, at the end of your model run write the values to the table using a process flow or fixed resource trigger. Maybe that will give you some ideas?
