Run and re-run model by Flexsim Script
simpson_s2
simpson_s2
[ FlexSim 20.1.3 ]
I have built a simple to run repeatedly with changing variables so I would like to create a script to start, change variables and then restart repeatedly. Each time it will run automatically, generate an .xlsx file for the result, and then alter the variables by Python script.
I have searched the answer from https://answers.flexsim.com/questions/106222/command-to-open-model-and-run-from-scripts.html.. I found it is time consuming for each iteration to open flexsim application , run the script and then alter the variables.
In stead, I am trying to use Flexsim Script to do, so it can save the time to open and close flexsim application. However, I found Flexsim will not run the scripts line by line, i.e. it will run all the line excpet 2 x go(), then run the first go() only with runspeed 30000.
Could anyone help me on this? Thank you so much.
/**1st iteration*/
resetmodel();
runspeed(10000);
go();
stoptime(90000);
getvarnode(Model.find("Tools/TimeTables/Worker_A1"), "table").as(Table)[1][3]=33000;
/**2nd iteration*/
resetmodel();
runspeed(30000);
go();
stoptime(90000);
joerg_vogel_HsH
simpson_s2
Hi Joerg, thanks it work! Now I am troubling the different results from manual run and experimenter respectively but the variables are the same. Do you have any ideas? Thanks
