rows are not loading into global table from database table
anil_kumar_n
anil_kumar_n
[ FlexSim 18.1.1 ]
I have a database table which consists of around 1000 rows(appr.). All the rows are shown in oracle database. Whenever I try to connect to table by running query in DBConnector it's not importing the data from table and it's showing an empty global table. How to resolve this issue? This happens with only few tables.
JordanLJohnson
Can you import through the API? It may be that the auto-import code isn't correct in some cases. Once you set up your connection, try this code (modifying variable names, etc.)
Database.Connection con = Database.Connection("DBConnector1");
con.connect();
Database.ResultSet set = con.query("SELECT * FROM mytable");
Table table = Table("GlobalTable1");
int tableSizeCorrect = 0;
int rowCount = 1;
while (set.fetchNext()) {
	if (!tableSizeCorrect) {
		table.setSize(1, set.numFields);
		tableSizeCorrect = 1;
	if (table.numRows < rowCount)
		table.addRow();
	for (int i = 1; i <= set.numFields; i++) {
		Variant val = set;
		table[rowCount] = val;
	rowCount++;
Jordan Johnson
Principal Software Engineer
emily_hardySTLSK
@ANIL KUMAR N, did this answer your question?
