Routing using labels
hf_96
hf_96
[ FlexSim 19.0.0 ]
Hi, I have a labeling problem in flexsim 2019 because of the unavailability of the matching label types functionality, thus I haven't been able to route the flow items in the loop (processor 2 --> queue 1 --> processor 3 --> processor 2 --> processor).
If there's another labeling technique i could apply to create this loop, i would much appreciate the help.
joerg_vogel_HsH
You need a trigger of the properties in the source to create a Label by Set Label. Whenever you access this label, please make sure that the label name matches always. In Flow tabs you set the property in Send to Port "By Expression". In 3rd processor you change on Exit Trigger the label value to 2. Then the item is exiting the 2nd Processor from 2nd output port. You reset the label on 2nd processor On Exit Trigger back to 1.
Please draw the connection from an output object to an input Object.38643-label-routing.gif
hf_96
Thank you for your answer, however, I haven't been able to follow the modifications in the properties some follow-up would be great thank you.
joerg_vogel_HsH
@Hi C, sure, what do you want to know? Can you upload your model with the connections I have in my animation and some of the triggers I mentioned above?
hf_96
I apologize for the late reply, I have actually found the solution by using another routing technique which is by item type
Thank you again.
joerg_vogel_HsH
Type is just only a label. It is not any different to my answer.
hf_96
Yes I am aware of that, personally it seemed much simpler.
