Route containers based on quantity of items inside
talia_z
talia_z
[ FlexSim 20.0.9 ]
Hello! In my model I have a tote that is placed on a pallet; within the tote there are a number of spheres ranging from 0 to 5. I am hoping to route the pallet object containing the tote and spheres to one of the two queues based on the quantity of spheres inside the two containers. If there are 0 spheres inside, the object should be routed to Queue1 and if there are 1 or more spheres inside, the object should be routed to Queue2. I am unsure how to access this property using decision point logic and would appreciate any insights you may share!
I have created a test model to work through this issue - it is attached below.
Route_containers_based_on_quantity.fsm
jason_lightfoot_adsk
The expression to test on the decision point will be:
item.first.subnodes.length>0
route-containers-based-on-quantity_jl.fsm
talia_z
Hi @jason.lightfoot! Thank you for this accurate response! I have one quick follow-up question. I have two different object containers that are moving through the system - pallets with totes and pallets with another pallet attached. Is there a way for me to identify which object this expression affects, as it should only be applied to the pallets with totes that are moving through the conveyor system? The other object will always be routed to 'Queue1'. I have attached the model including the additional object container type.
route-containers-based-on-quantity-jl2.fsm
You could test for the name of the thing on the pallet:
item.first.name.startsWith("Tote")
or, as I have done in the attached model, put a label called something like containerType on the flowitems and test that
item.first.containerType=="Tote"
route-containers-based-on-quantity-jl3.fsm
talia_z
Both options work very well in my model, thank you @jason.lightfoot!
