Route change by item type
__ANON_USER__1
__ANON_USER__1
[ FlexSim 21.0.5 ]
Route change by item type,
Is there a way to do this without using a process flow?
With the attached FlexSim data,
When the item type is 1, the first route from the top,
When the item type is 2, the second route from the top,
When the item type is 3, the third route from the top,
joerg_vogel_HsH
Weighted Routing by Label value, if you can use FlexSim 21.2. There you can add costs of a path and thus you can divert taskexecuters to different path routes.
In earlier versions you can insert in your tasksequences a travel task to a control point which is reachable by your conditions.
EDIT: source code in On Receive Tasksequence trigger of Operator
In a standard task sequence, created automatically by FlexSim this task should rank as 4th task. If you load more items, then this additional travel task must only be present in the transport tasksequence for the last loaded item.
route_change_by_type-JV.fsm
joerg_vogel_HsH
anonymous user , I updated your model.
ryan_c10
Hi anonymous user, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
