Round Robin if available not working with batch
armand_j
armand_j
[ FlexSim 21.0.0 ]
I have a model with 2 queues on which I can have 12 totes of different products (delivered on batch from a washing process)
The next process is another batch process of 4 totes. Before this process I place a queue to create my batch of 4. Not possible to mix the tote into this process.
The pull strategy "Longest Waiting" is working fine, making a FIFO between my 2 queues.
But I want to be able to test another method "Round Robin if available" but this is not working as I want, the operator will not respect the batch of 4 totes from the same queue but will go the other queue if material is there...
Note: I tried Open/Close ports but the operator is not considering it.
How can I do Round Robin if available for a full batch of 4?
Can the program of the round robin function be modified to round robin each 4 times ?
jason_lightfoot_adsk
Are you using transport? Can you post your model here? Make it private if necessary.
armand_j
@jason.lightfoot
Here a small model, I want operator to take from the queue a full batch of 4 boxes in alternance OR if not available to take from previous the queue
So, doing a "Round Robin if available" each 4 trays.
Round Robin vs Longest waiting.fsm
allister_wilson
We solved Armand's problem in an online meeting.
Armand, please accept this answer or comment back if you need more help on this matter.
For anyone having a similar issue, example model attached.
armand_j
Thanks @Allister Wilson for the support, solution integrated to my model.
