Rotating a "person" task executer visual
annakamphaus
annakamphaus
[ FlexSim 24.0.2 ]
I wanted to make a model where I could create task executors in code. It wasn't obvious for me how to do so I used some of the new (to me) people activities. Then changed the 3D visual file to be objects more relevant to my model, I replaced the girl "person" flow item with a dump truck and the staff with a loader. This works well except for one issue with the "person" moving in the model.
I can't seem to control the direction the people(trucks) are facing. I have tried rotating this within the flow item and using a change visual activity but neither have the effect I want.
Can someone recommend another way I can change it so these appear to travel facing forward?trucks.jpg
FelixMoehlmann
The main reason to use "Create Person" is to also automatically create a token in an Object Process Flow that is linked to the created task executer flow item.
Creating a task executer flow item and assigning it to a label on the token is just as easily done with the "Create Objects" activity.
If you want to create custom objects, I would recommend to add and customize them in the Flow Item Bin, rather than after creation.
After you apply a custom shape, make sure that it is oriented correctly relative to the coordinate system of the object. The 'forward' direction is the positive direction along the x-axis (red).
If the imported shape is pointing in the wrong direction, set the "Shape Factors" under "More Visuals" to correct this.
logan_gold
Hi @Anna Kamphaus, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
