Robot motion path by item
francesco_maria_v
francesco_maria_v
[ FlexSim 22.1.0 ]
Hello everyone,
I am new to flexsim and i am trying to model a simple pick and place operation as follow:
Two different objects are generated with a lable (ObjType 1 or 2) inside a queue and depending on the label, each object is picked and place by a manipulator one of two different processors.
I want the robot to execute two different motion paths (that i have already created) with a trigger "OnLoad" as follow:
if item.ObjType = 1 use path x otherwise use path y to reach the station.
is there a way to access the path i want to use through scripting?
thank you everyone for the patience, hope in some help!
moehlmann_fe
If you create the task sequence via code you can pass in the path number as a parameter when adding a task that involves travel. The used parameter normally defines the end speed, so when using it to set the path, the path number is signed with a minus.
TaskSequence.addTask(TASKTYPE_FRUNLOAD, item, robot, 0, -pathNumber)
The attached model demonstrates how this can be used (among other things). Depending on the height of the item, a different motion path is used.
RobotArm_ExampleModel_22_1.fsm
For more details, see the documentation.
francesco_maria_v
thank you very much for the help! this is what i needed
