Returning string from C++ user command
mischa_spelt
Advisor Advisor
mischa_spelt
[ FlexSim 17.0.0 ]
I'm importing an old (7.x) DLL to 17.0 and running into some problems with user commands returning a string. We used to write functions like
visible double DLL_GetDateTimeString( FLEXSIMINTERFACE )
  stringreturn( "Hello world!" );
  return 0;
but that does not seem to work anymore. The documentation states that as of FlexSim 2016 one can "simply" return a string from the user command, but I tried a couple of options such as
visible std::string DLL_GetDateTimeString( FLEXSIMINTERFACE )
  return std::string("Hello world!");
and
visible char* DLL_GetDateTimeString( FLEXSIMINTERFACE )
  std::string result = "Hello world!";
  return apchar( result );
or
visible const char* DLL_GetDateTimeString( FLEXSIMINTERFACE )
  return result.c_str();
but they break the stack or give me nonsense output, respectively.
Could you provide an example of how to return strings from a DLL function in version 2017?
philboboADSK
Change your function definition to return a Variant:
__declspec(dllexport) Variant DLL_GetDateTimeString(FLEXSIMINTERFACE)
Phil BoBo
Sr. Manager, Software Development
mischa_spelt
Thanks @phil.bobo, tried that but then I get an exception as soon as I try to use the parameters. Turns out that the definition of the visible macro in basicmacros.h that we were using is still defined as
#define visible extern "C" __declspec(dllexport)
which is appropriate for functions returning double, but when returning Variant the function needs to have C++ linkage.
Replacing "visible" with "__declspec(dllexport)" as per your example solved the problem.
anthony_johnsonT83CM
Mischa, you are correct and this is by design. Dll functions that use the old method of returning a double should always be declared as visible double MyFunc(FLEXSIMINTERFACE) whereas functions that use the new method of returning a Variant should use __declspec(dllexport) Variant MyFunc(FLEXSIMINTERFACE). FlexSim detects whether the function is exported as a name-mangled c++ function (__declspec(dllexport)) or as a simple c function (visible). If it is the former, FlexSim assumes the function returns a Variant. If it is the latter, FlexSim assumes the function returns a double.
