Return value from second column based on value queried.
suraj_j
suraj_j
Hello
I can't recollect if there is a function that returns a value from 2nd column of global table based on value that is given in first column.
e.g. From following data, if I enter 'SomeFunc("Table",0.8) I would get 190 (rounded above).
.25
100
.5150
.75175
1.0190
I know about d/c/empirical. The number in first column is not random but calculated.
Any help is appreciated.
SCHamoen
@Suraj J
As far as I know there is not. But it is very simple to create your own usercommand and have this function. Something like this would do:
double value = param(1);
for( int i = 1; i <= Table("TheTable").numrows; i++ )
	if( Table("TheTable")[1] >= value)
		return Table[2];
suraj_j
I guess I have to take this route then.
joerg_vogel_HsH
You get your return value by an Table.query.
Table.query("SELECT target FROM TheTable WHERE input >= $1 ORDER BY input ASC", col1Value)[1][1];
The Reset trigger contains more lines of code, because I want to show how you get the value. Line 7 is the code you need. Attached is the model in Flexsim 18.1.1.
query-table-for-return.fsm
