return to point of origin
francisco_t
francisco_t
[ FlexSim 19.0.4 ]
Hello everyone! I wanted to know how I can make a TE return to its point of origin following after having performed an operation along the same path it was, and avoid being stopped at that point, thanks!
JordanLJohnson
You can make a TE go anywhere by giving it a travel task. In general, you can save off the current location of a TE. When the operation is finished, you can give that TE a task to travel to that saved location. If the default navigation doesn't re-trace the navigators steps, consider saving off key locations as the TE performs the operation, and then navigate to each of those locations in reverse.
Jordan Johnson
Principal Software Engineer
francisco_t
Perfect, thanks! but I need to know the script to achieve it, can you explain it to me?
JordanLJohnson
How to do that depends on which navigator and task executor you are using. I can't be more specific unless you post a model that shows more details.
Jordan Johnson
