Retrieve all nodes connected to a network node via code
rohan_v3
rohan_v3
[ FlexSim 21.0.4 ]
Trying to get all the nodes connected to a given network node. I want to store them in an 'Object' variable and use for further logic. I explored the tree to see if I can sample something but couldn't find it. the 'connectionsout' node cant be used for sampling the connections.
jason_lightfootVL7B4
Connections out will work - a simple recursive function will do what you want.
rohan_v3
Was able to do it with following code. Needed to slice the string to take the 'To' out and obtain object name.
Array array = Model.find("Floor_1Cross_1_2").find(">connections/connectionsout").subnodes.toArray();
string obnum = array[1].name;
int length = obnum.length;
string obnum_new = obnum.slice(4,length+1);
Object nn = Model.find(obnum_new);
You could just use outObjects or the value of the connection node and finding the ownerobject of that.
rohan_v3
Yeah.. for some reason I thought out objects wouldnt work.. Well then its a very easy problem.. Haha.. nevermind then... Thanks!
