Reset-button vs. resetmodel();
niphon_jeepjua
niphon_jeepjua
[ FlexSim 20.2.3 ]
I was wondering, if there is a difference between resetting the model using the 1712755458868.png -button and coding 1712755426282.png: in our model, which we are not allowed to show, unfortunatelly, pressing the 1712755458868.png- button results in unwanted changes of values in global tables, which does not happen, when we reset the model via 1712755426282.png in the script- field. Comparing the Event-Logs after ressetting the models in both variations did not indicate any differences. Do you have any ideas?
jason_lightfootVL7B4
This works correctly in version 2022 and later. We recommend you move to a supported version.
Hi @Nip J,
We just want you to be aware that your FlexSim version is past its End-of-Life date and is no longer eligible for paid technical support. For more information, please see the article "Lifecycle and End-of-Life".
Community members here may still be able to offer advice, but please be aware that many features have been added and bugs fixed in the years since your software version was released. You may find that an offered solution that works in more recent versions of the software is not compatible with your old version, or that a posted sample must be opened in a recent version.
Contact your local FlexSim distributor for information on upgrading or getting a trial license.
Good luck!
