Require multiple tokens to acquire one piece of equipment?
justin.watkins54DXV
justin.watkins54DXV
[ FlexSim 22.2.4 ]
I am programming a process that uses an acquire location/equipment for an "Incubator" as a batch is being placed inside it so when the next batch comes through it chooses the next incubator instead of placing all batches in one.
However each of these incubators have multiple shelves.
Is there anyway to only acquire a piece of equipment after 3 tokens have passed and are using it?
but the moment one shelf is freed up have it become available again.
kavika_faleumu
Hey @justinrusty, this might be a solution you could try. incubation.fsm
In the top right, you can see "Incubators" are pushed onto a list. They're just tokens that represent each incubator.
Tokens are created in "batches", then get put together with a Batch activity. They then pull an Incubator that is ready to receive a batch. When the incubator is pulled, it is unavailable to other batches until it is done "incubating". When the token is done incubating, it will push the incubator back on the list, ready for another batch to pull and use.
