Representation of Zero Value in Graphs
borja_lorenzo4278
borja_lorenzo4278
[ FlexSim 24.1.1 ]
Hello
In the “Tiempo en los Buffers NOJIDOKA” graph, there is a noticeably different representation compared to those created directly from the Staytime section. It only assigns the times to the queue “PCBs_NO_JIDOKA.” The rest of the queues have a value of zero; this is also seen in the “standard” graph, but they do appear, at least in the legends.
What do I need to change in the configuration so that this looks the same or at least all the queues from the collector appear in the legend?
Image.png20240801_CP11_libro_FlexSim_Jidoka_6.fsm
This question is related to a previous discussion: input vs time for sink to dasboard using statics collector - FlexSim Community
moehlmann_fe
Observer
Observer
Set the "Change Rule" of the On Staytime Change events to "Update". This will create a data point even if both the previous and new value are the same (in this case 0).
In general you can only show values in the legend for which there is at least one data row present in the Statistics Collector table.
