Replenishing the warehouse when a material reaches a defined quantity
Ablanco1
Ablanco1
[ FlexSim 23.1.2 ]
Oinaz.fsm
In this model, the queue takes a planned demand of materials from the warehouse, by means of a table, but the intention is that the warehouse is filled as it is emptied. That is, when it reaches a specific quantity (in this case 3) it is filled up to the maximum (in this case 12), in each material.
Nowadays it is set to fill all the gaps at the beginning.
I am not able to realise that when a material reaches (for example from 12, initial quantity) to 3 that it is filled up to the maximum again.
I would be very grateful for your help.
Thank you very much for your help.
Jacob_White
Hi @Ablanco,
The following link goes to a similar question on the forum. The model in that question works similarly to what you are trying to accomplish in your model.
https://answers.flexsim.com/questions/127079/needs-help-creating-a-multi-echelon-supply-chain-m.html...
Ablanco1
Thank you for sending me the link to that other question. I will look at it in detail to see how I can do it.
julie_weller
Hi @Ablanco,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
